Viewing 3 posts - 1 through 3 (of 3 total)
  • #1816
      Stock plug for the 2.8T is NGK PLFR6C-10G (platinum)
      Stock Gap = 0.95 mm (+/- 0.05 mm)
      Colder plug – NGK PLFR7C-10G (platinum)
      Stage 1 & 2 recommended plug: Denso Iridium Power IKH22 5345
      Alternate: NGK LFR7AIX-11 Iridium
      Recommended gap (to minimize misfires) 0.80mm
      • This topic was modified 11 years, 3 months ago by VTuner.
      • This topic was modified 5 years, 5 months ago by VTuner.
      • This topic was modified 5 years, 1 month ago by VTuner.
      #2612
      I’m currently running a stock 2007 Aero and have plans for a stage 0. Idle is a bit rough so I’ll be changing the spark-plugs prior to the tune. Do you recommend IKH22 gapped to 0.85mm on stock and stage 0 or should I stay OEM? What’s your thoughts on Champion Iridium 9033? I like the fact that the ground electrode is platinum…
      Thanks!
      #2626
      Brian Blair
      Participant
        I would go ahead and install the Denso Iridiums – they will come gapped at ~ 0.80 mm out of the box and it is fine to install them at that gap setting.
      • You must be logged in to reply to this topic.
